T3 with golf engine
Nico96
Aufbauart/Ausstattung: T3
T3 with golf engine
Beitrag von Nico96 »
Hi everybody, i know golf 2 and T3 had same engine. Is it possible to put a syncro golf 2 engine in a 2wd T3?
Re: T3 with golf engine
Yes, it is possible. They own the same 827st block.
Which engine do you prefer?
Nico96
Wich parts can i use from a golf engine? I have 1.6 td
I ask again - which engine is installed in the golf? There where no diesel syncro golf 2 produced.
Nico96
Sorry i didn’t understand, it’s a 1.8 8v
Well, you truely need the whole engine, the wiring with the control module, ignition coil and the fuelpump, in case there is a outside pump used.
The oil pan you need to use from the bus, also the enginemounts and maybe the exhaust system. You have to build your own pipe in a freestyle way :mrgreen:
"Is it possible to put a syncro golf 2 engine in a 2wd T3?"
" 1.8 8v"
yes
which engine du you have
1.8 GU with pierburg carburator?
or
1.8 GX with Bosch Ke-Jetronic?
"Wich parts can i use from a golf engine? I have 1.6 td"
- shortblock and head and the whole injection/ingnition parts/fuel
- you have to install carburator oder ke-jetronic in flat angle (like in the golf) but the engine install in bus has a banking angle. so you need to do some fitting concernig this problem.
- and you also will need a lot of parts of your diesel instal: oil pan, engine mounts, water hoses and fittings, crankcase breather (and maybe valve cover). so don't throw away jx parts
perhaps this link helps:
http://www.fallwild.de/ateam/t3.htm
(the gearbox fittigs described there you won't need to do cause you have the right t3 diesel gearbox which fits the golf engine)
Nico96
Thank you both for the answers, but my question were is possible to trasform a 2wd t3 in a syncro with golf parts?
Thank you and sorry if i didn’t exlpained well
caravelle c
Beitrag von caravelle c »
Nico96 hat geschrieben: 13.01.2020, 18:26 Thank you both for the answers, but my question were is possible to trasform a 2wd t3 in a syncro with golf parts?
Simple answer: No.
You need all T3 Syncro parts, from front diff with subframe, Syncro gearbox to tank and front suspension.
Golf: front wheel drive based, with transverse front engine
T3: rear wheel drive based, with longitudinally rear engine.
matzmann
Modell: T1
Leistung: 44 PS
Motorkennbuchstabe: H+
Beitrag von matzmann »
caravelle c hat geschrieben: 13.01.2020, 18:59
Simple answer: No.
And lots of welding.
Osku
Aufbauart/Ausstattung: 88
Leistung: 69 ps
Beitrag von Osku »
65-T1 1500 45PS
87-T3 Syncro 1.6TD JX 69PS
88-T3 Syncro 1.9TDi ALH 150PS
Nico96
Simple answer: No.
I thinked i could use the gearbox maybe. But i discovered that 1.6 td golf syncro doesn’t exist. In anyway thank you
For the video i’ve yet seen but i don’t undestand too good English by listening :roll:
Osku
Leistung: 69 ps
Beitrag von Osku »
The whole driveline is different in e.g. country golf witch is the closest to what you might tink about. but as the engine is in the wrong end and the engine is in different position and even the rear diferentia is different so not one singel part is bolton.
https://encrypted-tbn0.gstatic.com/imag ... fKTjWAXI&s
65-T1 1500 45PS
