2wd to syncro
- Aufbauart/Ausstattung: T3
2wd to syncro
Hi, i wanted to convert my 2wd in a syncro. I wanted to do the work slowly when i have money and time. But i have a question, can i put a syncro gearbox on my 2wd without the front axle and without all front parts? It could work or i will break the gearbox? It’s like have a syncro with “disgiuntore” (i don’t know how to say in English) that disconnect front axle? I sould only change the engine supports and gear lever for now? So for the Moment i have a 2wd with differential blocks and then i will finish the conversion. Is it possible? Are there other solutions? Thank you all
Re: 2wd to syncro
Hello Nico,
sorry, my infos are in German, but look here:
http://www.2wd-goes-syncro.de/?paged=3
http://www.2wd-goes-syncro.de/?paged=4
http://www.2wd-goes-syncro.de/?paged=5
Somebody did it years ago.
Re: 2wd to syncro
Hi thank you but i don’t understand so good German, does he only use rear gearbox or he’s simply trasforming a 2wd into a syncro?
- Osku
- Aufbauart/Ausstattung: 88
- Leistung: 69 ps
Re: 2wd to syncro
You have to cuange the front gearbox mount to syncro mounts and then it fits. You can drive the syncrogearbox without the propshaft as the slip is in the front diff.
65-T1 1500 45PS
87-T3 Syncro 1.6TD JX 69PS
88-T3 Syncro 1.9TDi ALH 150PS
Re: 2wd to syncro
He did a complete change to a Syncro.
