Feldjäger elektrics
Moderatoren: gvz, jany, Staff
VW_Sk8r
Aufbauart/Ausstattung: 1990, westfalia
Leistung: 90 PS
Motorkennbuchstabe: AHU
Feldjäger elektrics
Beitrag von VW_Sk8r »
Hi for a start sorry for writing in English my German writing is very poor but feel free to answer in German reading shouldn't be to much of a problem.
I am dutch and since about a month I own a Feldjäger syncro 14 inch. In the Netherlands there is very little information about these busses. So that is why I am asking here. My bus was born as what I believe is called a funkbus. Because there is still some evidence of the antenna on the roof. I am converting the bus to Westfalia style campervan to go overlanding. At this point I am trying to figure out how to connect all the electrics. I know that there are 2 generators but only one seems to be still connected. Does annyone know why the installed two? I am thinking about using the second one to charge my household battery. But I am not sure if this is possible.
CBSnake
Aufbauart/Ausstattung: Bus
Motorkennbuchstabe: MJ
Re: Feldjäger elektrics
Beitrag von CBSnake »
every Feldjäger has a antenna. A Funkbus has two of them.
The second Generator use 24V because the Radio use 24V.
You can converte/change it into a 12V one.
https://bulliforum.com/viewtopic.php?f= ... 7&p=634457
Greetings
Bild mit Autogas
