TDI Pump Dusse.
- jabba
- Modell: T4
- Leistung: 102 PS
TDI Pump Dusse.
Hallo bulli fanatics!
So many time since i've give you news from my bulli.
I try to fit a 1,9 L TDI pump dusse engine inside my westy.
1st i've found a donnor car:
2nd i've done a custom oil pan:
Now i have to make engine brackets.
I'm searching for pics of such adaptation. Does anyone else have done the job here???
I've found this in germany:
http://kuehnel-concepts.de/index.php?op ... &Itemid=53
I've send us an email to see the brackets on the engine in the bus, but he doesn't answer me. Perhaps, it's because of my bad english.
Re: TDI Pump Dusse.
Hi there...
I've found this one on the site, you linked above:
Maybe it helps? Good luck
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Thanks, but i've found the engine brackets on kuehnel website. I've email him to see pics of his brackets inside a bus (a customer bus or his bus...). He doesn't answer me.
No one to tell me: "yes, i've ever seen this in Germany" ???
Does my topic is boring?
- Domi
- Leistung: 50
Re: TDI Pump Dusse.
Your topic isn't boring. But a Pumpe-Düse modification is very rare. Many people say that the gearbox can't handle the torque of the engine. So they just put other engines in their busses. 110Ps AFN TDi for example...
But the time of Pumpe-Düse modifications will come, just because good AFN engines are getting rarer and rarer, especially with less kilometers...
Grüße: Domi
Grüße: Domi
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Hallo Domi,Domi hat geschrieben:...
You're right. It's exactly why i choose a TDI p.d. The milleage of my engine is only 6050 Km, while the milleage of the AFN i found was over 200 000 Km.
For the gearbox there is solutions. Mine is to modify a 4 gears from aircooled with good rings from USA.
I'm just surprised that a German specialist doesn't answer me. Especially if there isn't a load of requests for such modification.
Nevertheless, i thank you for your help.
Greets from France.
Stéphane.
- Mr.J
- Motorkennbuchstabe: AGG
Re: TDI Pump Dusse.
Hello Stephane !jabba hat geschrieben:Domi hat geschrieben:...
Greets from France.
Stéphane.
maybe the reason the specialist doesn't answer is that you sent the request by e-mail. A lot of very good specialists over here are "scared" by writing/reading e-mails, especially when they come from abroad ...they prefer using a spanner or a hammer instead of that "modern" computer things ... also, it might happen, that an e-mail with a foreign adress goes straight through into the spam folder , so maybe he doesn't even receive it . Maybe you should try and call them, maybe they speak english or even french ?
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Yesterday i've take my phone and call Mr René K for the engine brackets matter.
My oral English is very bad , but i think he had understand my request. He had asked me to send him pics of my engine and "motortrager" to see if his custom brackets can fit with my engine (code BLT) and motortrager of my bus (4 gears 1982).
Now i'm waiting for his answer.
The matter come from the turbo side, the right side is easyest to do, i've done it.
If you want me to send pics don't hesitate.
Greets.
Stephane.
Greets.
Stephane.
- tce
- Administrator
- Aufbauart/Ausstattung: Int.
Re: TDI Pump Dusse.
olalalalala
* Bertl (doofer alter Sack)
ex* Syncro * Afn * 2 Sperren * Bimobil-Kabine *
- boofrost
- Norddeutscher
- Leistung: 1XX
- Motorkennbuchstabe: ADY
Re: TDI Pump Dusse.
Hi
Nice Job with the Oil Pan !!!
what kind of intercooler is it ?
air to air ? Behind the bumper ?
I tried nealry every kind and position of an Air to air Intercooler in my last Mtdi conversation, and in the end i bulid an Water To Air intercooler ....
http://www.bulliforum.com/viewtopic.php?f=36&t=15512" onclick="window.open(this.href);return false;
if you need a translation just giva a noise ...
Regards, Paul
Regards, Paul
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
I've ever seen a "water/Air cooler solution" from a Canadian call David Marshall.boofrost hat geschrieben:Hi
Thank U!
It comes from a passat TDI 130hp bigger than the original one in the seat FR TDI 130.
air to air ?Yes Behind the bumper ? yes, behind the rear light, i've cut the metal where was the original air filter to let the air come throught the aircooler? Exactly under the place of your water/Air cooler. Nice job Paul!
Uploaded with ImageShack.us
Regards, Paul
- boofrost
- Norddeutscher
- Leistung: 1XX
Re: TDI Pump Dusse.
Oh Yes man !
How much space is between Oilpan and Floor ? I think i need a PD Diesel engine ...
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Héhéhé,
My engine is not lower than the original one. But my westy is dropped with H&R springs.
- Leistung: 174 PS
- Motorkennbuchstabe: AAA
Re: TDI Pump Dusse.
Looks good & sounds good!
Mr. J and me have just done a engine swap on my Bus to a AGG engine, i know how much work & time you need to do this.
Gruß Ruben
brummmmmmmm.........
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Yes it takes me many, many time, i wouldn't get by without the help of some friends.
At this time it's not yet finish. Theres is still some troubles on my cluster.
Where is your thread with the gti engine?
- Leistung: 174 PS
Re: TDI Pump Dusse.
jabba hat geschrieben:Yes it takes me many, many time, i wouldn't get by without the help of some friends.
what does cluster mean? where do you have problems?
here is a thread with some pictures of my conversion:
http://www.thesamba.com/vw/forum/viewto ... highlight=" onclick="window.open(this.href);return false;
Gruß Ruben
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Cluster is the word for all the wire.
My dashboard has no light when i light on the headlights, multi fonction doesn't work, "blinkers" doesn't work...
- jabba
- Modell: T4
- Leistung: 102 PS
Re: TDI Pump Dusse.
Hallo Bulli fanatics,
After 3 years without any trouble with my engine gearbox swap i've sold my bus (since 1 week now). I'm getting older and my family is growing up.
I'm looking for a more confortable ride for my family with air condition and 3 points belts on the rear seats.
So, i'm searching for a T4 california 102hp after 2000, ideally a Freestyle green (fresco) to remind me my former Green bus.
If you heard something for sale wich match with my search don't miss to let me know about it. My email: stpg@msn.com
Greets and good holidays with your bus.
Stéphane.
Stéphane.
