TDI Pump Dusse.
this subforum is dedicated to our dear english-speaking vw-bus-drivers... feel free to ask, mention, and contribute on all topics regarding vw vans!
Moderatoren: jany, Staff
jabba
Modell: T4
Leistung: 102 PS
TDI Pump Dusse.
Beitrag von jabba »
Hallo bulli fanatics! :mrgreen:
So many time since i've give you news from my bulli.
I try to fit a 1,9 L TDI pump dusse engine inside my westy.
1st i've found a donnor car:
2nd i've done a custom oil pan:
Now i have to make engine brackets.
I'm searching for pics of such adaptation. Does anyone else have done the job here???
I've found this in germany:
http://kuehnel-concepts.de/index.php?op ... &Itemid=53
I've send us an email to see the brackets on the engine in the bus, but he doesn't answer me. Perhaps, it's because of my bad english. :tl
Revoluzifer
Motorkennbuchstabe: CS
Re: TDI Pump Dusse.
Beitrag von Revoluzifer »
Hi there...
I've found this one on the site, you linked above:
Maybe it helps? Good luck ;-)
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Thanks, but i've found the engine brackets on kuehnel website. I've email him to see pics of his brackets inside a bus (a customer bus or his bus...). He doesn't answer me.
No one to tell me: "yes, i've ever seen this in Germany" ???
Does my topic is boring?
Domi
Aufbauart/Ausstattung: Bus
Leistung: 50
Re: TDI Pump Dusse.
Beitrag von Domi »
Your topic isn't boring. But a Pumpe-Düse modification is very rare. Many people say that the gearbox can't handle the torque of the engine. So they just put other engines in their busses. 110Ps AFN TDi for example...
But the time of Pumpe-Düse modifications will come, just because good AFN engines are getting rarer and rarer, especially with less kilometers...
Grüße: Domi
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Domi hat geschrieben:...
Hallo Domi,
You're right. It's exactly why i choose a TDI p.d. The milleage of my engine is only 6050 Km, while the milleage of the AFN i found was over 200 000 Km.
For the gearbox there is solutions. Mine is to modify a 4 gears from aircooled with good rings from USA.
I'm just surprised that a German specialist doesn't answer me. Especially if there isn't a load of requests for such modification.
Nevertheless, i thank you for your help.
Greets from France.
Stéphane.
Mr.J
Aufbauart/Ausstattung: Doppelkastenkabine
Leistung: 115 PS
Motorkennbuchstabe: AGG
Re: TDI Pump Dusse.
Beitrag von Mr.J »
jabba hat geschrieben:
Greets from France.
Stéphane.
Hello Stephane !
maybe the reason the specialist doesn't answer is that you sent the request by e-mail. A lot of very good specialists over here are "scared" by writing/reading e-mails, especially when they come from abroad ...they prefer using a spanner or a hammer instead of that "modern" computer things ... also, it might happen, that an e-mail with a foreign adress goes straight through into the spam folder , so maybe he doesn't even receive it . Maybe you should try and call them, maybe they speak english or even french ?
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Hello Mr J,
Thank you for the possible explanations. :bet
So, would you try for me to ask him for pics of his brackets on the engine? :bier
Modification for oil level & oil sump:
And my friend Manu, has open my gearbox for change the 3rd and the 4th ring:
greets.
Stef.
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Yesterday i've take my phone and call Mr René K for the engine brackets matter.
My oral English is very bad :mrgreen: , but i think he had understand my request. He had asked me to send him pics of my engine and "motortrager" to see if his custom brackets can fit with my engine (code BLT) and motortrager of my bus (4 gears 1982).
Now i'm waiting for his answer.
The matter come from the turbo side, the right side is easyest to do, i've done it.
If you want me to send pics don't hesitate. ;-)
Greets.
Stephane.
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Now, i'm here:
tce
Administrator
Aufbauart/Ausstattung: Int.
Re: TDI Pump Dusse.
Beitrag von tce »
olalalalala :bier
* Bertl (doofer alter Sack)
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Hi Tce :bier
My work (still) in progress:
boofrost
Norddeutscher
Leistung: 1XX
Motorkennbuchstabe: ADY
Re: TDI Pump Dusse.
Beitrag von boofrost »
Hi
Nice Job with the Oil Pan !!!
what kind of intercooler is it ?
air to air ? Behind the bumper ?
I tried nealry every kind and position of an Air to air Intercooler in my last Mtdi conversation, and in the end i bulid an Water To Air intercooler ....
http://www.bulliforum.com/viewtopic.php?f=36&t=15512" onclick="window.open(this.href);return false;
if you need a translation just giva a noise ...
Regards, Paul
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
boofrost hat geschrieben:Hi
Thank U! :mrgreen:
It comes from a passat TDI 130hp bigger than the original one in the seat FR TDI 130.
air to air ?Yes Behind the bumper ? yes, behind the rear light, i've cut the metal where was the original air filter to let the air come throught the aircooler? Exactly under the place of your water/Air cooler. Nice job Paul! :bet
Uploaded with ImageShack.us
Regards, Paul
I've ever seen a "water/Air cooler solution" from a Canadian call David Marshall. ;-)
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
boofrost
Norddeutscher
Leistung: 1XX
Re: TDI Pump Dusse.
Oh Yes man !
How much space is between Oilpan and Floor ? I think i need a PD Diesel engine ...
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Héhéhé,
My engine is not lower than the original one. But my westy is dropped with H&R springs. ;-)
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
T3-Ruben
Leistung: 174 PS
Motorkennbuchstabe: AAA
Re: TDI Pump Dusse.
Beitrag von T3-Ruben »
Looks good & sounds good!
Mr. J and me have just done a engine swap on my Bus to a AGG engine, i know how much work & time you need to do this.
Gruß Ruben
brummmmmmmm.........
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Yes it takes me many, many time, i wouldn't get by without the help of some friends.
At this time it's not yet finish. Theres is still some troubles on my cluster. :-?
Where is your thread with the gti engine?
T3-Ruben
Leistung: 174 PS
Re: TDI Pump Dusse.
jabba hat geschrieben:Yes it takes me many, many time, i wouldn't get by without the help of some friends.
what does cluster mean? where do you have problems?
here is a thread with some pictures of my conversion:
http://www.thesamba.com/vw/forum/viewto ... highlight=" onclick="window.open(this.href);return false;
Gruß Ruben
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Cluster is the word for all the wire.
My dashboard has no light when i light on the headlights, multi fonction doesn't work, "blinkers" doesn't work... :roll:
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Hallo Bulli fanatics,
After 3 years without any trouble with my engine gearbox swap i've sold my bus (since 1 week now). I'm getting older and my family is growing up.
I'm looking for a more confortable ride for my family with air condition and 3 points belts on the rear seats.
So, i'm searching for a T4 california 102hp after 2000, ideally a Freestyle green (fresco) to remind me my former Green bus.
If you heard something for sale wich match with my search don't miss to let me know about it. My email: stpg@msn.com
Greets and good holidays with your bus.
Stéphane.
jabba
Modell: T4
Leistung: 102 PS
Re: TDI Pump Dusse.
Beitrag von jabba »
Moin, moin,
It's been à while since i give some news here.
This is my new bus t4 california génération tdi 102cv (130 now :lol: )
Zurück zu „English-Corner“
