Hi all,
My reverselights do not function. I've looked through the documentation but can't find where the switch is located. If anyone has a pic or a document, that would be greatly appreciated!
Thanks
Reverse Light Switch position?
Re: Reverse Light Switch position?
on the left side, of the gearbox. Or better: across the Point where your Gearstick goes into the gearbox
Or do you have Automatic Transmission?
Greetings
Greetings
mit Autogas
- Krillo
One of the connectors had come loose.
Cleaned the contacts with steel wool and contact cleaner, then connected them.
Works no problem
That was a quick and easy fix, thanks again!
/K
Works no problem
/K
